2008 M45 Headlights
chestnut
Car: 2008 M45
Can I disconnect the motor to my headlight that makes noise? I think the motor is giving out. Has anyone done this?
TXT
Car: 2006 M45 Sport
People do it all the time. Do it.
vasekvi
Car: 2008 Infiniti M45 S
Im new here so pardon the newbiness. Is there a reason other than failing or noisy motors to disable the motorized headlights?
chestnut
Car: 2008 M45
Thanks TXT. Is it simply a plug or do I have to disassemble the Headlight?
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
chestnut wrote:Thanks TXT. Is it simply a plug or do I have to disassemble the Headlight?
Have you tried to turn off the switch (AFS) to your left where the key fob slot is at? Not sure if it'll shut it off until you turn it back on, or if it's something that would require you to press every time you start the car. Other then that :gotme you may try looking for a plug or fuse to the AFS!
chestnut
Car: 2008 M45
Thank you. I will try that. I really appreciate all of this info.
