humblepie »
https://forums.nicoclub.com/humblepie-u121352.html
Mon Dec 01, 2008 11:52 pm
The more I drive this car, I'm beginning to feel the issue I'm experiencing is a direct result of a combination of my driving style and the muffler. The issue is most noticeable in the 4th and 5th gears.
When driving and I barely have the foot on the gas (just enough to keep the RPM steady), then the noise is at a minimum and I'm at constant speed. However, the problem is that on most terrain, you have slight inclines as well. So I need to give a little bit more gas than is required to keep the RPM steady (or else my speed will start to drop). So this is when I apply a bit more gas, then I start to hear a very low pitch growling noise partly from the engine, but I think most of the noise that annoys me is magnified by the muffler.
So can anyone suggest some mufflers that might minimize this effect I'm hearing? Or if I don't know what I'm talking about, then please enlighten me as well.
-------- UPDATE 1/1/09 ----------------
I took my m35 to the dealer to have it checked and they found that the exhaust pipe leading to the muffler was offset - probably due to some object on the road hitting the pipe. I just got the m35 back and found that the noise at ALL levels are much quieter and smoother.
No longer does my cabin floor resonate and no longer do I hear an excessive low freq drone at lower RPM range. And the quality of sound from the engine revving up to higher RPMs is much smoother tone than the raspy noise I heard before. I'm so happy now
The only issue now is I'm noticing a slight drone when @ idle from the exhaust. I think it's more pronounced if I have the fan/AC on, but will have to test it more.
Modified by humblepie at 2:03 AM 1/1/2009
