Wuher »
https://forums.nicoclub.com/wuher-u123094.html
Mon Mar 09, 2009 7:01 am
Since the carputer will use the auxiliary video input to display it's output on the factory monitor, I needed to make the auxiliary video input work when the car is in motion. I've frequently searched, but haven't seen anyone discuss the details of enabling video while in motion on a non-nav (base) 2008 M35. Therefore, I decided to see if I could figure it out on my own, using the existing navigation hack information and the Infiniti service manuals.
As it turns out, it's actually significantly less work than the widely discussed "navigation hack", since you don't need to solder wires and add a switch somewhere in the cabin. However, you do need to know which wires to use, since M35 models with navigation or mobile entertainment use different wiring harness pinouts than the base (non-nav) model. In order to get started, I had to access the AV control unit, which required removing the cup holder, seat heater controls, shifter area, and the clock panel. For more detailed instructions on removing those items, with pictures, check search for the general “navigation hack” info.
As I've marked in the attached pictures, the wires we're interested in are the parking brake signal (106) and the vehicle speed sensor (107). At first, I tried cutting both of those, but for whatever reason, I actually had to attach them to ground to make it work. Therefore, after cutting those two wires ~3" from the harness, I stripped 3/4″ off the ends still attached to the harness and used a wire nut to tie the two wires together with a piece of speaker wire, which I attached to a Torx bolt on the AV control unit’s metal frame.
See my blog post about this for more info.
