Damn. Thanks.
I'm assuming you're talking about this?
http://www.crutchfield.com/p_581PA15INF ... tml?tp=120
Apparently it
does work but it's a severely crippled solution. i.e., can't navigate your playlists with the car in motion, can only go through one track at a time, uses the 6 disc changer screen, etc.
This is why you should research before buying. If I could go back I'd get one without the factory nav. It's such a PITA.
One more question if you (or anyone else) doesn't mind. Can I just keep the factory nav and replace the disc changer at the bottom of the dash? If I can replace it with an aftermarket touchscreen, I'd be satisfied.
