2008 G37s blowing fuses on blower not working
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
gr8ride22
Car: 2008 Infiniti G37S
Hello I wanted to see if any had any experience with this before, my A/C blower fan is not working and checked the fuses on the fuse block by your left foot kick panel and the two blower fuses are blown , I checked around and people said to replace the blower/accessory relay but that didn't work it blows the fuse as soon as the car is started. I've read there is a AMPLIFIER for the blower fan that that could be the problem does anyone know about this?
audtatious
I've never had an issue with the A/C on mine at this point. I'd suggest digging through the FSM to troubleshoot: http://www.nicoclub.com/FSM/G37/Coupe/2008/
gr8ride22
I tested the Blower motor and it was bad, put in a new one and it works good now.
gr8ride22
also I disconnected the battery and the window didn't go up atomatically but I found the fix to roll them down all the way and then up all the way and hold the button for 10-15 seconds. it worked
audtatious
Excellent. Glad you figured it out.
Saints4me
Car: 2009 G37 Journey
I have a 2009 G37 Journey. I just changed the battery and cabin filter and discovered both 15A blower fuses are blown
I replaced them twice and they blew as soon as the start switch was activated. I pulled the blower out and replaced the fuses and they are still good so I'm thinking it's the blower itself.
I put 12Vdc to the motor direct and it works? What am I missing? Could the motor still be bad?
Joey
telcoman
Saints4me wrote:I have a 2009 G37 Journey. I just changed the battery and cabin filter and discovered both 15A blower fuses are blown
Joey
Are you using an OEM cabin filter or something else?
If something else is it interfering with the blower motor?
Try without the filter or put the old one back for a test
Telcoman
Return to “G35 and G37 Interior, Exterior and Audio”
