JDeeze »
https://forums.nicoclub.com/jdeeze-u188787.html
Mon Aug 08, 2011 2:20 pm
Hi,
I recently purchased a 2008 G37s 6mt and I must say, that car makes driving a great experience! The car had ~19k mi when I first bought it. I did run into an issue around 21k mi where the slave cylinder went bad and had to be replaced. I was pretty upset, but got over it since it was completely covered under the mfg's warranty.
1.) Has anyone ever heard or experienced a slave cylinder going bad so quickly? Could the previous owner have possibly driven the car so hard that it caused this type of failure?
The real issue that I would like to address is the car's overall performance. When I first bought it, the car had amazing acceleration and speed!!!! Especially when you hit 3rd-5th gear, it felt like when you hit the gas, the car suddenly just let loose an explosive burst of speed!!! Lately, I've noticed that it doesn't have quite the same "kick", especially in 1st gear. If I'm at a stop light and begin to accelerate it seems to have some hesitation before accelerating. The technical spec on the car claims 0-60mph in ~5.5s, but I can tell you mine feels more like 0-40mph in ~5.5s.
Technical Info:
When I had the slave cylinder replaced the Infiniti dealer performed a Multi-Point Vehicle Inspection and noted that the In-Cabin Microfilter and Engine Air Filter were dirty and recommended that they be replaced. I did not replace either at that moment. Based on my reading it sounds like the Engine Air Filter plays a big part in vehicle performance and efficiency. The inspection was performed when my car had ~21k mi. It now has ~23.5k mi.
2.) I plan to bring it in for service this week (replace engine oil and filter, engine air filter, etc) and wanted to know if there are any other recommendations to improve my car's performance?
Based on my research, it's recommended to:
-add fuel injector cleaner every ~3-5k mi (although this is debatable based on the Owner's Manual)
-keep spark plugs clean
-keep tire air pressure ~3psi higher than recommended
-keep all air filters clean
-keep clean oil in the engine
Thanks
