From what I see this calculator is actual pretty close. I checked it against various tire manufacturers recommendations and basically it comes in within 1/4 to 1/2 inch and typically within 1/4 inch of their recommendations. So I would say it is safe to say that if you take in a 1/2 inch maximum difference in recommendations and stay towards the center of the calculator range of rim sizes you should be well within the recommended range regardless of tire brand.RED_DET wrote:245 series up front and 265/275 rear. http://www.1010tires.com and use the tire size calculator to determine the best aspect ratio.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
