2008 g37 with fault code p1091
2008g377
Car: g37
Hi everyone. Bought a 2008 g37 with no warranty. It has 88k. It recently went into limp mode. 1200 rpm max. My friend has a consult III. Scanned the car and found fault p1091, vvel act mot pwr. When I clear the fault it comes back instantly before I even start the car. I removed the connector for the top vvel motor and checked power with the key on. No voltage. I did some reading and swapped the vvel relay with the pwm relay. fans come on with the vvel relay, so it it good. I removed the vvel and checked for signs of corrosion. none found. checked continuity between the relay harness and the vvel module harness. I think pin 24 and the 2 harness at the relay had continuity. if I start the car with the module removed it has the same fault, and no more. what powers the harness to the vvel motors? the module I assume. Sorry for the long post. thanks guy, feel free to move if this needs to be in another section.
Reason: Revised title
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO! I've revised your title to reflect the nature of your problem. I'm not all too well versed in your vehicle, but can offer an option for you.
Here at NICO, we have Factory Service Manuals available free to members. Take a look at the link in my signature and find the FSM for your car and you'll have all the info you'll ever need to make the repair and try to diagnose it for yourself while help is on the way.
