2008 G37 Stuck in Reverse
nissankid08
Car: 2008 Infiniti G37
Hi folks. Have an issue with my automatic 2008 G37s. Was backing out my driveway this morning. Reversed out fine. Put the car into drive, the car still reversed. Park, is park. Reverse works. Neutral, drive, and manual selections all make the car reverse. The cluster shows the correct selections. Reverse lights work on reverse. No linkages seem broken. Oil still good. No leaks. 43k miles. Any suggestions? With no warranty, im afraid of a dealer diagnosis.
telcoman
nissankid08 wrote:, im afraid of a dealer diagnosis.
Then take it to Jiffy Lube.
I'm sure they know how to fix it if you don't trust a dealer. :chuckle:
Telcoman
Starter
Car: 13 G37X sedan
11 G37S sedan
Depends on the dealer. Some are good and some look at it as an opportunity to share your wealth.
There are lots of good independent garages around. Find one of those if you don't trust your local dealer.
DarkMan2555
Car: 2006 Infiniti G35 Sedan 5AT w/ 157k+ miles
So what happened?
