Hamed wrote:Ya, I'd like to keep it, but if you suggest a part that won't compromise the life of the car I'd happily put it on.I checked with my dealer, they only have a Nismo exhaust system, nothing else. I want an air intake and a suspension system, but don't know which ones to get.
Well see that is the problem. If you use non Nissan approved parts you may well just void the warranty.
For example there is a fella here that had his engine blow up. Regardless of what the actual precipitating factor was it cost him over 13k to fix outside of warranty since that ended up being voided.
Stillen Long Ram Intake, Stillen HFC, Stillen Brakes, UR Pulley, Cobb Protune are some of his mods. Stillen is advertising a set of mods including intake which is suppose to net you 50+ horses. My guess is this setup just may end up voiding your warranty if something happened that could remotely be tied to an engine failure.
Even if a dealer installed the modification and gave you a warranty and wrote you up some sort of legalese that it would not void your warranty I think you could end up with only that dealer honoring it in the end.
Often times you will see posts here about aftermarket parts being warranteed, I have a feeling that if you really read the warranty you would find that the aftermarket parts which were dealer installed do carry a warranty against 'their' failure, which of course doesn't help you much if what they are attached to fails.
My suggestion is to be very careful here and maybe go above the dealer to maybe the Infiniti regional rep and get their permission when it comes to what is approved.
Perry
