But then, I noticed some rust that I thought was odd. For instance, the plastic shield sitting on top of the radiator has four bolts running across the top. The two in the middle are fine (rust free), but the two on either end have heavy rust accumulation. Why would 2 be so rusted, when the other 2 are fine? Wanting to see how far the "problem" went (not sure if it really IS a problem, except that I want to replace the bolts because they're ugly), I removed the plastic shield that sits on top of the engine. For the most part, everything looked fine, but then I peered down the back of the engine and saw the dual exhaust manifolds. I cannot believe how rusted those things are. Those nuts are never coming off--not that they need to any time soon, but still. What is the deal?
Another thing I noticed is that the hood doesn't seem to seat properly. When shut, I can push on the hood, and there is a tiny bit of play (it rattles if I rapidly push down and let up on it). Visibly, you can't tell anything is out of the ordinary, but it just doesn't seem right.
I'm probably just being paranoid, especially since the Car Fax was clean, but I'm worried something might be amiss. Should I be concerned about any of this???
