2008 g35s---how to remove gear shift knob
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
ruudeboyy1211
Car: 2008 g35s
wassup yawl.....does anyone know how to remove the gear shift knob so i can remove the entire center console?
im about to do that bypass video "surgery" but i wanted to remove the console so i can make a hole for the wires neatly....
suggestions, answers, ideas welcome..
Modified by ruudeboyy1211 at 1:04 AM 11/5/2009
joe603
Car: 2014 Durango R/T
Welcome to NICO!
Check out the G-series FAQ (link in my sig) for a few links that go in detail on the bypass. I'm not sure if there's info on how to remove the shifter...but we do have FSMs that might help.
Let us know if you cant find it!
terrycs
ruudeboyy1211 wrote:wassup yawl.....does anyone know how to remove the gear shift knob so i can remove the entire center console?
You can download step by step instructions with pictures here:
http://www.activetechdesigns.com/11201.html
ruudeboyy1211
Car: 2008 g35s
thank u terrycs..but i actually meant the knob on the gear shift..i have to remove it so that whole assembly where the e-brake is can be lifted up..if u run across anything else, let me know..
ruudeboyy1211
Car: 2008 g35s
hey thanks joe, but i still couldnt find anything on removal of that 6mt gear shift knob
terrycs
ruudeboyy1211 wrote:thank u terrycs..but i actually meant the knob on the gear shift..i have to remove it so that whole assembly where the e-brake is can be lifted up..if u run across anything else, let me know..
The knob is basically screwed onto the shifter handle and it is a PITA to get off because there is thread-lok in it. The FSM says to lift up the bezel and use two adjustable pliers .. one on the shaft under the bezel and the other on the knob using a piece of cloth to prevent destoying the finish on the knob.
If you want pictures, look in the FSM, section TM, page 18.
ruudeboyy1211
Car: 2008 g35s
ok thanks..ill check it out...
Return to “G35 and G37 Interior, Exterior and Audio”
