2008 G35 + Stillen Short Ram Intake
FrankieFresh
Car: 2008 Infiniti G35
I have a question. I have a the stillen short ram intake. But the wiring for the MAF sensor is not connected anywhere. So, when it gets too hot it begins to melt a bit. In the stock system there is a clamp to hold it down. What can I do? Where do I connect it so its just not out loose? What have others done?
Here is a pic:
FrankieFresh
Here is the driver's side:
Is it supposed to be just left out like this??
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
what is melting? It shouldn't get hot enough to melt any wiring..
the way you have it wired should be fine as long as its not being bent by the hood.
you might have that shrink wrap adjusting a little bit, but that is normal.
