Had a weird problem today, got home and pushed button to switch off engine. The instrument panel shut down briefly, but the engine continued running. Instrument panel came back on showing service engine soon. Further pushes of the start button to shut the engine down just resulted in the same result. I ended up having to pull the fuses for the ignition system and that shut it down.
I replaced the battery a few weeks ago and it's been working fine. Is there any reset to the BCM module that has to be done after the battery is replaced?
Any ideas what could result in this behavior? Hate to take it to the stealership.
Thanks in advance for any help,
Bob
