2008 EX35 with G37Xs Coupe Y-PIPE/MIDPIPE/MUFFLER INFO/PICS
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
jrmotorsports55
Car: 2011 EX35 AWD Journey (wife's car)
Really like it. Barely noticeable as far as sound goes, just has a more aggressive rumble at idle and when accelerating. It passed the wife test. I think there is a little more performance as well.
Would definitely do it again.
Thanks,
Jason
AWGD8
Car: 2008 EX35 AWD JOURNEY
Great to hear that you are liking it ! How long did it take you to cut and weld the midpipe? I might just do the same, but i have to find a shop who will do it for cheap. Also reweld back the hanger from original location.
jrmotorsports55
I have a little $200 flux core mig, so I did it myself. Took 15 minutes. Used a sawzall to cut out the section after first drawing a straight marker line so I could line the pieces up after the section removal. Tacked it in place, made sure all looked well, then ran the bead. Wire bushed it, then a quick spray of silver paint. All done!
Jason
AWGD8
Thanks for the info. I bet it will be more expensive if shop does it. I might fix mine in Aug.
AWGD8
Here is an update to my Muffler tips. In reference to JRMOTORSPORTS55 midpipe mod below,
post6587063.html#p6587063
I did follow where JR cut the midpipe (1 7/8 " ) My performance shop did cut 1 1/2 " only since they did not remove the exhaust bolt at all. They just raised the car and cut and welded under. That is a good thing since I do not have to worry about new exhaust gasket. I paid $ 60 for cutting and welding and moving back those 2 hangers (MIDPIPE) to the original position and pushing the exhaust inwards toward the front of the car. Now tips are not sticking out and looks STOCK! :dblthumb:
BEFORE:
AFTER: :dblthumb:
Thanks for the tip JRMOTORSPORTS55 ! :woot:
jrmotorsports55
No problem, looks good!
65432N1
Car: 2010 EX35
Hi Guys,
I'm doing the same mod to my 2010 EX, so thank you for all the work that has gone into this. Have the G37 Coupe exhaust and ready to install.
Question: Did you use new exhaust gaskets? Or the old gaskets from the EX or the G?
Thanks in advance!
jrmotorsports55
Reused.
Jason
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
