2008 Armada - Right Low Beam not working
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
chabr
Car: 2008 Nissan Armada
Just started not functioning the other night. Changed the bulb and checked the fuse, still no go, high beam and fog are both fine. Any thoughts before I bring it in to the shop?
marctronixx
when you mean "not functioning" are you saying the lamp does not illuminate on the low beam? may look like a dumb question but just confirming.
look at the harness in back? socket may be faulty/have water damage.
can you pull the harenss off the lamp housing and check continuity with a ohmmeter or similar?
Return to “Armada Forum / QX56 Forum / QX80 Forum”
