2008 Altima Coupe Stereo help !!
Post all your Nissan electronics, car audio and stereo questions here!
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
I just bought an 2008 Altima Coupe 3.5L SE and I love the Factory system but want to add my old system to it. I have a Alpine-450 Amp with a single Infinity 12" dvc Sub. I have read about needing a line output converter, but also heard that if your amp has speaker inputs you don't need the converter. So, my question is how do I wire my system?? I have always worked with aftermarket H/U not OEM ones. HELP !!!
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
There are many speaker level converters out there. Soundgate makes some very clean full range units for $50ish. The PAC SNI-15 is usually fine for $20ish.
mpbclutch33
So can I just tap the rear speaker wire to the Amp speaker inputs, or do I have to go the converter route?
Here is what the amp I have looks like. See the Speaker level inputs.... What connectors would I need to connect to that?
Modified by mpbclutch33 at 2:39 PM 2/22/2008
