7HP from a intake on a naturally aspirated engine thats a 4 banger....no way never maby 1. Read the fine print on the intakes and such they will say up to 7hp not 7hp gain. Now if you were forced induction then you would be seeing 5-7HP. Also you don't have a cold air intake that would make a big difference you have a hot air intake which hurts performance so you could and when sitting idle at a light probably loosing 2-6HP by having your engine suck up your engine heat saturated air.dldjros69 wrote:http://www.kandn.com/dynocharts/69-7061_dyno.pdf
175 hp - 123 hp = 52 hp loss (175 x .30=52.5)
That seems like a 30% loss. Is that correct?
My next question is
The K&N intake gains 7 whp. How do you do the math to find what the regular hp would be?
Or should i not be doing this?
Thank you in advance
I was referrring to Intake gains, really you might even lose hpdldjros69 wrote:How is that a perfect condition? Both runs were extremely hot. The first run was 93 degrees the second was 100 degrees. That doesnt seem like optimum conditions to me. Since it wasnt moving no air was flowing into the airbox.
So does 30 % loss sound right? That is really high!
dldjros69 wrote:i cant see a loss of hp.
I agree that your gonna see more gains with a CAI than a WAI. But i cant see a loss goin from stock to a WAI. yes your takin in warm air but the heat from the inside of your engine bay will effect the air in your stock setup as well, the box is only plastic and is not insulated. a short ram air is gonna increase the flow of air over a stock setup. More air + more fuel = more power. Most people buy a ram air for the sound rather then trying to pick up a few more horses.soltys wrote:I could see a loss - not huge, but a loss. Cold air is more dense then the hot air in the engine bay. More density means more flows to the motor and generates more power. That's why Cold Air Intakes generate more power gains then the Short Rams.
175x15%=26.25-175=148.75wHPdldjros69 wrote:http://www.kandn.com/dynocharts/69-7061_dyno.pdf
My next question is
I still have air from the outside aimed at my intake too... its not perfectly aimed there but i am getting fresh air to it....soltys wrote:I agree that the engine affects the stock plastic box but the stock setup also has a feed from the front of the car. As pathetic as it is, it does allow fresh air to directly enter the filter. As does the AEM and K&N setups - they are as close as you can get to a CAI.But like you said, no one buys a SRI for power gains - it's all for sound and looks.
That's not an accurate comparison though... The 140whp for the A/C is calculated after drivetrain loss (hence the wheel horsepower)...you should find out what your Neon was pulling at the wheel for proper comparison. It was probably somewhere in the 80-90whp range. Also, horsepower isn't the most important thing in "smoking" another car...torque is. The QR is probably has the most torque of any four cylinder I've ever driven.dldjros69 wrote:Exactly forest. my coupe feels like a corvette compared to my last car. I had a dodge neon with 134 hp. There is no way that my coupe has 140 hp. My coupe is 500 plus pounds heavier and smoked my neon.
Porsche has less drive train loss due to engine over the rear transmission.08Coupe wrote:With the new SAE Engine Dyno regulations it's not likely Nissan could overrate there HP readings. Also that dyno run was in second gear and I don't think the Altima second gear is even close to "1 to 1" ratio! As a standard Stick 13-15% drivetrain loss, Auto 15-20%...RWD and FWD not much difference...AWD=19-25%.
And LOL my harley puts down almost what they got from the 2.5
