2008 Altima 2.5S will not start. HELP
General discussion area for the L32-chassis Altima
Mixturepinoy
Car: 2004 G35 Coupe Automatic!
My car has about 37k on it. The car died on the HWY after driving it for about 200 miles. the gas pedal lost pressure and the electrical turned off. We pulled over to the side and got the car towed to the house. I attempted to jump start it, but no luck. When we try to turn it on, the RPM's jump to 1.5-2k for about 5 seconds and the car turns off. All the indicator lights turn on when the car is started.
-Car has about 1/3 gas in the tank.-Car normally had standard oil changes. that day my wife took the car to a local oil change (oil can henrys) and they recommended full syn, so she got that. and they recommended some kind of fuel or oil cleaner, which she threw in the tank upon full fill up.-i checked underneath the car and i don't see any leaks, and the filter is on tight.
I'm not sure what it might be?
wade001
Car: '09 Nissan Altima Coupe S 2.5 M/T
so this happened when u were driving? could be the alternator. jump start wont work with a fully depleted batt, could start but wont run long as the car is running off the batt alone. let me know
Mixturepinoy
That's what I was thinking... but then again, the car isnt that old... weird. I'm getting it towed to Nissan tomorrow, I hope it isnt anything too big.. strange how the car just died while driving though..
Hapa180
Car: 1990 240sx 2008 Altima
what do you mean the gas pedal lost pressure? keep us updated
wade001
you can test the alternator yourself with a volt meter, charge the batt, start the car and read the batt volt, should be around 14.6-15V
01qwhite
Car: 01 Infinity QX4
looks like your outside your warranty but if you have done work at the dealer even if its just oil changes an maint. they can "good will" it for you with permission from nissan
Return to “4th Generation Altima Sedan (2007-2012)”
