sexybeasty »
https://forums.nicoclub.com/sexybeasty-u92616.html
Sat Apr 26, 2008 7:56 am
yeah, i know that's how it works. I feel like I idle the car along most of the time in mixed driving; i give it enough gas to get it rolling and let gravity do the rest. the car is great at coasting along at 45-50 mph with little accelerator pressure. The multi-function computer readout tells me I'm getting 23, but when I re-fuel (using the same gas pump at the same station) and divide miles driven by gallons used, it's usually in the teens. For instance, the last fill up (after my exciting 20mpg post) I used 12.3 gallons to go 188.6 miles. That's just over 15 mpg. Even when I fudge the numbers (round down the gallons used and round up the miles driven) to give the car the advantage, it still doesn't hit 16 mpg.
For anyone thinking there is something wrong with my math or the way I fill the car up, check this out. I tried this about seven fill-ups ago (which was like last week ...
To eliminate human error due to variances in auto-shutoff at the gas pump, I shoe-horned gas in at a trickle and literally topped it off until it poured out the fill pipe. I know it's not the best thing to do, but I needed to know if I was doing something wrong. I did this for two consecutive fill-ups and got 19 mpg. Again, this is during very conservative driving, and mostly at 45-55 mph on parkways to work and back.
I still love my car, but if I had known the 2.5 would get V8- like gas mileage during practical use of the car, I would have bought the 3.5. On my window sticker it says that in city driving, a car like this may not get it's rated 24, and that you can expect results between 19 and 27 city. To be truthful, Nissan should tell you that you will never (or rarely) see anything higher than 19, MIXED driving (I must mention I don't like in a city and see very few traffic lights). The only way I could get 24 mpg mixed with this car is if someone towed me to work and back while I idled the car.
BTW- Nissan looked at it and said the car is working perfectly.
