Scandinavian Flick »
https://forums.nicoclub.com/scandinavian-flick-u100311.html
Mon Aug 18, 2008 7:17 pm
sending it out to get analyzed sounds excessive, unless you truely need to know the exact amount of mileage left, i would just stick with the good ol' eye ball test, if it looks dirty then it is, if it looks clean then it is. or just change the oil every 3-5 thousand, and know that no matter what its clean and good to go,
here is something that a friend and I used to do, we both at the time worked at a rental car agency, i worked in the mechanics bay and every time one of us would have a oil change come around, we would put the car up on the lift, drain the oil, fill the car with the oil that is supposed to be used in the rental cars which is just like the most basic of basic 5w30's we would then run our cars for about 10 minutes, then drain the car again and then refill with whatever oil we supplied usually royal purple, yeah we wasted about 1.25 gallons of oil every oil change, but it didnt cost us anything, and we felt that it would help get the virtually all of the old oil out of the car and completely fill it with new, now whether or not it helped at all we didnt know, but we felt that it did,
