2007 Versa - Windsheild Fluid Pump
rhjo51
Hello, my daughter ran over something with her 2007 Versa and broke the bottom of the windsheild wash pump off. This is the part where the two hoses connect to. I'd like to see a diagram of these parts, and also to know if I can replace just the pump, or if I have to replace the tank also. Can anyone help please. Thanks - Jim
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There's a pretty decent set of diagrams on pages 4 and 29 here.
You actually don't need to remove the tank due to the way the pump is mounted. You can just disconnect the connectors and slide it out of the tank.
rhjo51
MinisterofDoom, that was very helpful, thank you! Do you know if you can get easy access to the pump with just the fender protector removed? Also, is the pump a Nissan item only or would my local parts store carry it? Thanks again for your help, very much appreciated. - JIm
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
If I remember right, you may not need to pull the liner back. I'd peek under the car to be sure.
Check your local parts store, but we have have some OEM parts suppliers that give us discounts. Look in the "Sponsor Spotlight" thread in the General Chat section.
