Super! My 2004 Frontier stays about 182 or so. Thanks for your numbers - it makes me feel a lot better.dl56zza wrote:I also have a SCAN GAUGE from scangauge.com. At highway speeds on level surface it shows 182-186 degrees. On a warm day at 0-10 mph in heavy traffic with A/C off, it cycles between 206-194 degrees. I have versa SL.
Thanks for the information.biggie wrote:First you should post up where you got the ScanGaugeII, I'm sure some people are interested.
For the most part 180-200 is normal engine operating temp for cars I've seen. On the 240s the stock fan doesn't even cut on til 212 degs or so. So you are fine.
I bought mine with an extra cable (for my Frontier). I hooked it up to the Computers and ran the cables to the steering columns (on both cars).CodeRed wrote:How do you hook it up?
Edit: i cant read....
The cable is detachable at the ScanGauge II and can be connected on the back or side of the unit. Once connected to your vehicles OBDII port, the ScanGaugeII automatically negotiates communications with your cars computer - It's that easy!
I think im going to buy one...
Now I know I definitely need one. My wife has driven the car for the last 5 days while I was on a business trip and came back to see I have less than half a tank with only 177 miles on it. Maybe this would help her see what mileage we should be getting.vpnavy wrote:
It is kind of neat because it actually affects the way you drive. I watch the MPGs and you can really see the difference between your RPMs and your MPGs.
Have only had it for a few weeks. So far everything appears to be dead on.bigdog wrote:looked @ scan gauge pretty cool. how well do the other features work on it ie: fuel to empty,mpg stuff like that?
I'll take a few pictures when the wife gets back tonight. I have it mounted on the Steering Column right in front of the instrument panel.
I would be interested in a group buy if we could get a reduced price. I'd like to have one mostly for the Trip Computer functions. BTW, I noticed with our CVT, going 70 MPH pushes only 2200 RMPs!lachancesare wrote:I'm a new Versa owner (cvt) and interested in a group buy. I find that my rpgs, if kept below 2,000, definately are making a big difference in my mpgs but I seem to have to keep letting up on the accelerator to get the speed and rpgs kept that wayI'd rather have a tool that helps me see exactly what I should be doing (I am NOT at all versed on autos but very interested in higher mpgs, as that is a primary reason I bought the Versa.
Thanks for the temperature spread. On getting an OEM - I don't believe the Versa has a true temperature gauge (not to mention I don't want to run all that stuff to install one. The ScanGaugeII provides what I need).Ever Victorious wrote:I'm sure that more than just the V owners would be interested in a group buy. let me talk to the mod staff and find out how to handle this... I may be back with a link to a new thread.
And as far as the numbers on the coolant go, that's very normal. most automotive thermostats will open at 190 degrees or 200 degrees. In fact, you can tweak your cooling system a little bit by replacing your thermostat with one that opens at a specific temperature... although on most vehicles I suggest just buying an OEM thermostat, since they're the best match and tend also to have the best gaskets.
OK - Here is a picture. The image inside the image is the Computer Connection and the Cable wrapped up in the Fuse Box area.
