2007 Versa 6 speed manual transmission mystery
boxcarbill
Car: '07 Versa SL hatch 6 speed white/beige int.
Does the 2007 Versa 6 speed manual have a TRANSAXLE which shares the MANUAL TRANSMISSION lubricating fluid with the differential in the same case?
I took my Versa to the dealer and they replaced my "TRANSMISSION" oil with:
"2 KE916-99071P MT-XZ GEARBOX 75W-80"
(I'm guessing it was "2" quarts)
Is this the correct lube, and did it refill the transmission AND differential case/s?
Thanks for any info.
Bill K
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yep, you have a transaxle, not a transmission. Fluid is shared. The M/T takes 4.5 pints of Nissan M+ 75W80 or API GL-4 75W80, so they used the right fluid.
boxcarbill
OK, thanks. I once had an auto shop replace my Tercel differential fluid with ATF because I had an automatic trans.
You can´t be too careful.
boxcarbill
VStar650CL wrote:
Wed Jul 03, 2024 7:38 pm
VStar650CL
Technical Expert
boxcarbill wrote:
Wed Jul 03, 2024 8:26 pm
OK, thanks.
:dblthumb:
:lolling: :lolling: :lolling:
