thanks for the input. it just seems a little too loud and notchy to what i've experienced before, but this is my first close ration 6sp so i didn't know if that was customary. another reason for my concern is also because it's only between 1st and 2nd, 2nd to 3rd and up are nice and smooth from the get-go. as far as the 2-1 shift, i am talking about being stopped. i have two stop signs close to my house right when i leave out of the drive way so i stop frequently right off the bat and it is just as bad shifting back down to first at the stops as it is going 1-2. anyone else with a 2007 MT having similar problems?nametakennow wrote:The B15 Specs were known for having loud transmissions when cold. Really any car I've driven has been a little extra notchy when started cold.
I hope you're not downshifting to first (you mentioned 2-1). First has no synchro, so it's not going to engage except at a stop or very slow roll without some force anyway.
YES. Mine started doing it after 1000 miles or so. I tried lubing up the bushings with red grease and it helped for about 200 miles. Right now, I just live with it until I read a TSB on it.jbarbaresi wrote:
Since I work at a Nissan dealer, when the issue comes up on Assist I'll let you guys all know.jbarbaresi wrote:has anyone brought their car into the dealership to get looked at yet? now that new prospector has said it's only gotten worse with his i'm starting to wonder if i shouldn't bring mine into the dealership and let them identify and fix the issue before it gets worse. only problem i see is that they are going to tell me its normal and not to worry about it.
