2007 Sentra Steering Wheel vibration
Ravel36
I have a vibration in my steering wheel that occurs at highway speeds. It gets worse or more prominent when the road is sloped down to the left. I have not checked the opposite sloping direction. On normal flat surfaces it vibrates but not as prominently.
Anyone have any ideas on what this might be? I have already replaced the drivers side tie rod end and I also had to re-lubricate the cv joint on the inside passenger side, the boot clip that was holding the boot in place was missing.
Ravel36
Bump
SoundEfx
Go to a shop and get the car aligned and balance the tires.
That should help.
ConnieKeefe
Car: vgf w wfwer rw rwr wr wer wrw
By any chance would you know your afr's?
To me it sounds as if the car is running rich, hence the hesitation and I say this because mine did the same thing.
Check your coolant and your air temp sensors. When I changed mine, it helped tremendously.
Ravel36
I don't have any hesitation in the car just vibration in the steering wheel at speed and most noticeable at the higher speeds. I do not know what the afr's are, But everything in the engine bay is stock with the exception of a K&N Air filter.
Ravel36
Just want to update this for the record. The vibration was caused by a bad passenger side CV axle shaft bearing. I removed the CV axle today and noticed a lot of play in the support bearing for the shaft. After replacing the CV axle vibration is gone. All is good now. Thanks for the assistance!
