Thanks for the reply! I will try what you suggest here, hoping it's not a ground/wiring issue... but we will see. What I do know is it started not starting the day after she took it through the car wash... Not sure if that is just coincidence but it's got me thinking maybe something got knocked loose or something.VStar650CL wrote: ↑Fri Dec 16, 2022 7:58 pmCam is more likely than crank on an MR engine, and a lot easier to try out. Either one can cause a no-start with no codes if it's lying to the ECM and not flatlined. Try pulling the cam sensor and see if it starts after a long crank. If not, plug it back in and disconnect the crank and see if that starts it. If neither one works then try turning the cam sensor 90 degrees in the bore with the retainer screw removed. If none of that works, it's unlikely your problem is the sensors (although it's still remotely possible they're both bad). One quick test for a bad crank sensor is whether your scanner gets a steady RPM signal while cranking, if the reading is zero or bouncing all over then chances are the sensor is shot.
The original codes you had indicate a problem with the ground wire or ground connection to the MAF (the IAT and MAF don't share power but they do share ground). However, they could have occurred if you pulled the MAF loose with the key on, so they may not mean anything.
