2007 Sentra Odometer is stored where?
o2sys
Car: SS 350z
Is the odometer memory settings stored in the ECU or the instrument panel?
If I replace my instrument panel will still display my current mileage?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
No, you will display the mileage the other cluster has stored on it.
Faja
Car: 2009 Nissan Sentra
RED_DET wrote:No, you will display the mileage the other cluster has stored on it.
^^^^^^^^^ That is correct. Also try to get one where the mileage is fairly close to your current one maybe slightly more and then run yours till the mileage is similar and then change it. FYI, the 2007 -2009 are interchangeable and get one that has the same features as your current one - for example if you have cruise and ABS. Ebay has quite a bit of them that's pretty cheap compared to new one from dealer.
