2007 sentra alarm wiring
orntar
Car: 2007 nissan sentra 2.0
i posted these questions at the12volt, and didn't get any responses.
i just opened up the kick panel and found 2 wire bundles, one presumably goes up to the door, and the other goes down into the floor. in the door one i found the 2 power door wires (pink/silver dots and red/silver dots), but there is a large gauge and small gauge, does it matter which one i tap into?
and, i assume, on the lower one i found the door trigger (red/white) and the parking light wire (red/blue). if i'm in the right spot and the color matches the database, should i just go for it? is there a way to test it with out striping the insulation?
thanks
nametakennow
Car: '06 MINI Cooper S
Check the wiring diagram in the FSM from the link in my signature.
Welcome to NICO!
orntar
thanks. boy, that's rather daunting though.
orntar
nametakennow wrote:Check the wiring diagram in the FSM from the link in my signature.
Welcome to NICO!
the "pg.pdf" does not work for me. is there a problem with it? i downloaded it a few times to verify.
michaelahess
Car: 2008 Sentra S
Try these"
http://techservices.codesystem....aspx
Username: DIYPassword: 852
or
http://wiringinstructions.com
Password B92F0136
or if you are really lazy, here's the excerpt from the '08 which should be the same I believe.
Constant 12 volts GREEN IGNITION SWITCH HARNESSIgnition 12 volts YELLOW IGNITION SWITCH HARNESSStarter WHITE IGNITION SWITCH HARNESSDome Light RED (+) PIN 63 16 PIN WHITE CONNECTOR AT BCM * **Trunk Pin Switch WHITE/GREEN (-) DRIVERS KICK **Parking Lamp RED/BLUE (+) DRIVERS KICKPower Lock RED DRIVERS DOOR HARNESS ** #201Power Unlock PINK DRIVERS DOOR HARNESS **
orntar
michaelahess wrote:Try these"
or
Password B92F0136
thanks, i have all that info already.
have you installed an alarm in your sentra? the problem i now have is just finding a suitable door trigger. i would prefer the dome light, but the red and black wires at the kick (going to the dome light), each always show 12v and ground respectively. i am measuring ground by continuity and 12v with a meter to ground. yet the dome goes off with the door closed.
the red/white wire in the wiring databases yielded the same something always ground, but made my continuity checker make a weird nose.
can anyone give me some insight? if i don't find it, i will just wire a switch to the alarm input so i can program it.
michaelahess
Car: 2008 Sentra S
Sorry man, can't help ya there, my '08 has the intelligent key with alarm.
damonfong0
Car: 2005 Nissan Sentra, 1990 Nissan 240sx, 2006 Volkswagen Jetta, 1995 Toyota Corolla, 1995 Honda Del So
or
Password B92F0136
OMG howcome I never stumbled upon this? it's like a goldmine of information!
