Hello,
I am working on an 07 sentra 2.0L
Popped up engine code - P0335.
Pulled out sensor, tested the prongs (between 1 and 2 I have 1.2k ohms, others 1-3 and 2-3 nada (O.L))
Bought a new one from bumperto bumper (aftermarket) cause dealers were closed, put in, still p0335. Checked the readings with the multimeter, same, 1.2k ohms and other 2 nothing.
I did test everything from the factory manual, like I have 5 volts going to the sensor, and continuity between two wires and ECM. The CKP test tells me the new one is DOA I guess.
What would readings look like if it was good? I will see if I can get one from the dealership
