2007 qx56 Keyless Entry-Control Module
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
davidwinn23
Car: 2007 Infiniti QX56
both key fobs stopped working at the same time. A locksmith checked the fobs & said they were transmitting & that it would be the Keyless Entry-Control Module. Can anyone tell me where this is ?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
See BL-37 here:
https://www.nicoclub.com/service-manual ... 7%2FBL.pdf
There's no separate RKE control unit like on older models, just an RKE Antenna/Receiver module that bit-bangs fob transmissions to the BCM on a 1-way LIN link. The Antennas rarely go bad unless there's a water leak at the passenger A-pillar that drowns them, and they're powered by the BCM so there's no fuse involved. I'd try an Antenna first simply because it's cheapest and easiest, but chances are better that your BCM has a memory failure. If so you can try having the fobs reprogrammed, sometimes ID data in the BCM simply gets corrupted and refreshing the ID's will restore function. If that doesn't work then the BCM will need to be replaced.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
