2007 Quest -Does the ECM need to be flashed after transmission replacement
A forum for the Nissan Quest... minivan lovers unite!
Adamquestdriver
Car: 2007 Nissan Quest
Hello all,
I have a 2007 Nissan Quest with the re5f22a transmission. I replaced it with another used transmission that is a direct fit. I am wondering if the ECM need to be flashed... The battery was disconnected for a couple days so I suspect that would reset it but read something about having the dealership flash it after a transmission replacement.
It seems like it went through a learning phase with a few rough shifts and strange down shifts. Now it seems to shift fine but on two occasions I have noticed a hard 4-5 upshift.
Thanks!
Reason: TYPO
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
I would recommend downloading the FSM from this site and reading the section on AT repairs. Or you can ask the dealer service department, and if they do not give you a satisfactory answer, call Nissan. HTH.
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
X2, the FSM will detail that type of thing in 'replace the trans' section.
Your new trans may have a fault...............the 4-5 thing. Common when they are swapped as entire units.
Return to “Quest Forum”
