VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Sep 12, 2024 3:03 pm
With Auto, the system will never kill the blower when the HVAC is alive. You need to hit the "Off" button. That's the only way to completely kill the fan, you can't do it using the fan speed buttons. Even with the Auto lamp out, you can only dial the blower to minimum, not turn it off. On Auto, if the cabin temperature is close to the set temp, it will dial itself to minimum and match the cabin temperature at the outlets. That's just the way Nissan Auto systems work, it's normal.
