4xq »
https://forums.nicoclub.com/4xq-u207684.html
Wed Aug 12, 2015 2:39 pm
Google recalls by vehicle model and you should see a NHTSA site where recalls are listed. There was not a recall for the transmissions on those, altho there may have been some deals worked out between Nissan and their customers that had problems. At 130k tho, I am almost sure there will be no help from Nissan.
There is an open recall for Takata airbags ( that affects most manufacturers and millions of vehicles) so you can call the dealer and see about that.
You should check the transmission fluid and see if it is pinkish and a little foamy looking, indicating coolant in the fluid. New transmission fluid is red.
