bigdaddychia »
https://forums.nicoclub.com/bigdaddychia-u95198.html
Mon Apr 21, 2008 4:41 pm
Yeah you read that right 100K miles. In only 20 months. Names Scott and I use my car for work and I drive a lot. So how has it fared for 100K miles. Well first off the only thing I had replaced under warranty was the steering wheel and shifter, as the oil from my hands apparently rubbed the silver paint black. As for maintenance, I have changed the oil about every 8-10k miles(synthetic), changed the transmission fluid twice(second one switched to synthetic), replaced the front pads at 96K miles. Changed the air filter 6 5 times. Whats next you ask? Spark plugs, and rear shoes that are squeaking. Guess it was the drums that needed to be changed and not the front. Infarct at 96K miles the front pads easily had another 30K left on them.
I did the spark plugs yesterday. Wasnt to bad took about an hour. Its fairly strait forward. All you need is a 8mm, 10 mm socket, 6 inch extension, and try and find a 14mm spark plug socket. If not you need a 14mm spocket and long needle nose pliers to get the plugs out. Also the plus are denso iridiums from the factory so makre sure thats what you put in it. Also there is a bolt for the intake manifold behind the throttle body so that has to be removed as well.
