Hello All,
New to the forum and hopefully I can get some answers without dumping more and more money into this thing.
I have a 2007 Quest SE I purchased last November (84k miles). Steering wheel controls didn't work so took to dealership and ran diagnostics and found it was spiral cable. They wanted 1k to replace it. . .I said screw you, bought part online for $125 and did it myself. Everything works great now (Bluetooth, cruise, volume) except ABS light came on and upon acceleration after you first start engine the ABS engages and locks up front wheels for a second or two. You're a sitting duck for those seconds. Not a great thing if you're turning left in front of traffic!
I read forums about resetting the ABS light which that works but doesn't fix the issue and the ABS light comes back on.
I removed ABS fuse to narrow down problem. The van runs just fine but brake light is on, speedometer and odometer doesn't work, no cruise control. So it's the ABS system somewhere.
Was suggest to replace ABS wheel sensors by stealership. That was an easy and fairly inexpensive fix. I did that myself and it did not fix the problem. The stealership said to bring it in for another diagnostic and pay another 100 bucks. I asked why the first diagnostic didn't pick it up and they said it was because of the faulty spiral cable.
I found that after I first start the engine, back out of the driveway, put it into drive. . . if I just coast for the first 5-10 seconds I will hear a faint electric sound (like a pump turning on) for 1-2 seconds. I know by now that after it makes that sound, I'm good to go. The van drives just fine the rest of the time. It's only happened within the first 10 seconds of putting the van into drive.
Modulator? ECM? Those are super expensive fixes from what I've heard but any suggestions y'all can give me would be most appreciated. I really don't want to throw any more money at the stealership.
JT
