pathme07 »
https://forums.nicoclub.com/pathme07-u225913.html
Wed Oct 02, 2013 10:26 pm
Hi, I'm new here and was referred here by a Friend. If anyone can help, I'd be more than grateful. (and willing to compensate for the solution).
I have a 2007 Nissan Pathfinder.
Today when I got out of the car and locked it, the passenger side window lowered all the way down.
When I turned the car back on, the passenger side window would not go up. It was stuck in a down position.
My first thought was the motor went bad, or there was a problem with the track.
I pressed the buttons and did not hear any clicks, nor did I hear the motor trying to run when pressing the buttons. It was completely silent.
When I pressed the window button on the passenger side I could neither raise the window or lower the passenger side window. It was dead.
I tried to raise/lower the passenger side window using the drivers side switch and that didn't work either.
The drivers side switches open and close all of the windows except the passenger side window.
The passenger side lock and unlock button work just fine.
In order to test the motor, I took off the door molding and got access to the window motor. Using a 12 volt battery, I was able to put 12 volts to the window motor and the window went up ruling out the motor being bad.
Questions:
1. Is there a fuse somewhere that operates the passenger side window, and if so where can I find it?
2. I was thinking the passenger side switch went bad, but the window would not rise/lower using the drivers side switch as well. Could this be the drivers side switch that went bad?
Any suggestions on what this could be and the solution. Any information would be much appreciated.
