2007 Nissan frontier climate control won’t illuminate after new radio
CtPathfinder
Car: 2004 pathfinder SE
Hello everyone
I need some serious help here I’ve been racking my brain for the last 48 hours I install the new double din and backup camera and now my climate control lights and shift indicator won’t illuminate I checked all the fuses doesn’t seem to be the issue I did pop my tail light fuse installing the radio at one point but any help would be greatly appreciated as I troubleshoot it all I know how to.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That stuff all runs off the taillamp relay, it's a grey wire on IPDM pin 57 that turns red after a splice in the engine box and stays red through 49G in the SMJ connector (E152:M31). Past the SMJ everything except the power window switches is on a common bus inside the Main Harness, there are no intervening connections. Check other stuff like your Hazard Switch, VDC Off switch, Door Mirror switch, etc. If they're all out then maybe you blew the fuse again, or maybe scorched a supply wire the first time it blew.
CtPathfinder
Thanks for the reply do you think it’s possible that I blew the bulbs on the climate control and the shift selector? Or more likely a scorched wire like you had mentioned?
CtPathfinder
Btw I checked all Fuses all the power outlets windows cab lights work
CtPathfinder
Just took the center Consol apart and found out that the buld was bad for the shift selector I wonder if it’s connected to everything else?
VStar650CL
Technical Expert
All the backlighting is on a common bus.
CtPathfinder
Not sure what you mean by that ?
VStar650CL
Technical Expert
It means the bulbs are all fed by the same two power and ground wires, it's all common.
CtPathfinder
Looks like the new bulb won’t light. This is so Frustrating. Do you think I can bypass power to it ?
VStar650CL
Technical Expert
Sure, you can jump either power or ground (whichever is bad) from any other bulb that is working.
CtPathfinder
Hi, just found out my driver side yellow light is not work either put new bulb in and it’s a no go. Maybe they are all connected?
CtPathfinder
Driver side rear meant to say
VStar650CL
Technical Expert
CtPathfinder wrote:
Thu Jun 17, 2021 5:35 pm
If you mean the front side marker, then yes, it's on the same fuse and relay as the backlights but uses a different wire coming from the IPDM.
CtPathfinder
Ok thanks So much for your help I really appreciate the feedback and Help. Just a quick recap I don’t have lights on the indicator shifter or the climate control backlit or one yellow driver side rear light it clicks on and off when you unlock or lock the doors. I have checked all fuses and even swapped some relays over to see if that was the issue everything seems to be working in cabin lights windows power locks hazards third brake light fogs etc. I just made an appointment do you have my mechanic look at it.
