WDRacing wrote:If you repeat this above "launch sequence" how often do you get the same results, where the transmission doesn't "shift"? I've beaten on a Alty with CVT and don't recall it hanging like that at all. How long does it hang?
Well, again, the one time I was at this light, and there was a new BMW M5 and a Mercedes AMG stopped in the other two lanes (sweet!)
So I launched hard enough to smoke the tires off the crosswalk paint, then had to lift (as the next light was red, and it was a 45 zone). The M5 punched it too, and was about even for the first 500 feet.
So when I punched it, I was up to around 50 mph at 6000 rpm, when I lifted, then I was going along for a good three or four seconds where it feels like the torque converter is locked to the engine, and I was seriously going to reach to put it in neutral, since the engine braking was so severe, (I was completely totally embarrassed as it was like I had shifted to neutral for no reason and was revving my engine at 5500 rpm when slowing for a red light)
I need to rig up a camera mount for my iphone so I can document this......
Again, I may be crazy, and this may be a way to prevent the engine from over-revving, since if you lift off wide open throttle under load, and the engine were allowed to freewheel, perhaps the revs would go too high, or some other bad thing unique to the CVT would happen.....
