WalterGA wrote:Update! Just got off the phone with either Goober or Gomer, over at the Nissan dealership in a small town near where I live. If that guy has an I.Q. over 82, I'll eat my Maxima, part-by-part. Will not be taking my Maxima to that toad. Unfortunately, I live over 200 mi. from the dealership in Atlanta where I acquired the car. Will wait until next trip to Atlanta in a couple of weeks, in order to discuss the problem with somebody more accustomed to speaking in polysyllables.
FWIW, the toad informed me that the 3.5 engine didn't use gaskets, that a "filler" was used. Does that sound right?
All I can say is what a _____ idiot your dealer tech is. Looking at page EM37 of the 2007 Maxima factory service manual clearly shows that there is a very conventional head gasket in use for each cylinder.
If you really did blow a headgasket, driving it any distance is likely to do more engine damage, like putting a hole in a piston.
Check your coolant level and inspect your oil for signs of milkyness (water in oil). A blown headgasket sometimes causes air bubbles to be seen in the radiator with the cap off, and in extreme cases causes the radiator to vent it's pressure.
There are coolant passages in the throttle body/intake manifold, and maybe just something there is leaking.
I would be really surprised if there are not some trouble codes stored in the ECU...a blown headgasket would cause it to store at least a few fault codes (cylinder misfire, I would guess).
