M45brasfield wrote:All, I have a 07 M45 that overheated Friday night. The return hose disconnected from the radiator. I reconnected the hose, refilled the coolant, bled the system and replaced the upper thermostat. It is still overheating and a Service Engine Soon alarm is on. Any ideas??
I have seen the SES light come on for overheating. The code was something like "engine over temperature", followed by a decrease in performance.
Does your car overheat almost immediately after warmup, or only in slow traffic?
Do the fans run?
Radiator clear of obstructions?
You didn't mention how long the engine ran while overheated, but you might still be getting the overheating indication because aluminum engines like ours don't handle overheating very well. Over a certain temp + duration a gasket leaks or engine component cracks and that's that.
To narrow down if a seal is compromised, are you seeing any of these symptoms?
1. White, sweet smelling smoke from the tailpipe
2. The engine oil looking milky
3. Coolant has an oily sheen
4. Too high or too low coolant level in the resevoir
5. Bubbling in the reservoir
6. The heater in your car doesn't seem to get warm unless you're in motion
And another maybe unrelated point - the return hose is the lower one/ driver side. These have pretty beefy clamps on and you'd need a good amount of pressure/obstruction to pop it off. Any idea what happened there?
