2007 m35x top gear?
maxrebo2
Car: 2007 infiniti m35x
i just bought a 2007 m35x and noticed that when the car reaches its 5th and final gear, it then sounds like it needs to shift another gear because it sounds like a lot of back-pressure. It sounds like when you're driving a manual car and are in a gear which needs to be shifted up. Is this normal for the car to sound that way since it's a luxury sports sedan?
Q451990
Sadly, it's made that way. I think our G revs way too high on the interstate... it has always felt like it needs a 6th gear at speed. It runs around 3K at 80 MPH I think...
Heath
maxrebo2
that sucks...i wonder if there is something that can be done to change the length of the gears...
Q451990
I suspect that changing the differential gearing would be easier, although it would kill your low end torque. You sort of get used to it after a while. The only justification I can think of is that they were trying to keep the engine in a "sweet spot" for emissions. I'd be curious to see how much better highway MPG would be with a taller top gear.
The '10 G has a 7 speed A/T... must shift more than it runs!
Heath
Q45tech
Easy to calculate as over the typical range: displacement x rpm.
Remember that each injector squirt is maintained at 14.7 A/F so at a constant speed, 10% gearing change will result in 10% fuel change PER UNIT OF TIME.
A 10% decrease in rpm from gear change will net out < 2.5% acceleration change. Acceleration a cube root of torque.
