mikew83 »
https://forums.nicoclub.com/mikew83-u251744.html
Wed Oct 14, 2015 3:55 pm
Here's the thing. The key opening all the doors, trunk, etc. has nothing to do with the ignition. You yourself can program the smart key to the car for window and door functions. There's a tiny chip inside that is responsible for starting the car. An Infiniti tech once warned me that they can easily fall out or be damaged when you're changing your battery. So you may have accidentally damaged your key. If that's the case, you need a new one. New keys are not too terribly expensive. They're about 130-150, plus programming at the dealer. You can probably find the fob cheap through infiniti parts online, or ebay.
Do you have the second key still? Does that one work, if you do?
The key for my 05 Q45 is $700 at Infiniti! Can you believe that?! It's not even laser, or smart key. Just a giant hulk of plastic like Volvos. Same key used on the 03-04 M's... It's looking pretty shabby too, but I'm not spending that.
