USMC5811 »
https://forums.nicoclub.com/usmc5811-u215192.html
Fri Feb 21, 2014 12:42 pm
My 2007 M35X recently started making a little noise in or around the front suspension. The noise is very subtle and almost like a droning noise that is consistent and gets faster as speed increases. I can also feel it a little bit in the drivers side footwell, almost like someone is tapping very lightly on the floor board from underneath.
Immediately i thought it was a wheel bearing, and I'm still leaning towards it being a wheel bearing. However today i rotated my tires, front to back, to make sure it wasn't a tire going bad or out of balance. while rotating the tires I checked for play in both front wheels, even though i think its the drivers side i figured id check all of them. There's no play in the wheels.
Also, from the day I bought the car, every now and then my front suspension will make a grinding noise that can be heard easily and also felt while making a sharp right turn at a very low speed. However it only happens sometimes and I usually can't recreate it if i try. I know there's a TSB about it so in the beginning i figured it could just be whatever the TSB says it is, i think its the steering column, but its not necessary to change it.
Once this constant noise started I wonder if the two are connected?
Anyone have any insight on what it might be? I think its the wheel bearing but could there be a different issue that created those same symptoms? My car has just over 100K on it and I live in NJ so its possible that the wheel bearings could've gotten rusted from salt on the roads after snow storms and such within the past 7 years.
Oh and my TPMS no longer reads the PSI in each wheel after I rotated them. Will it eventually fix itself?
Thanks guys
