2007 M35X FRONT GRILLE REMOVAL!!!
XGORILLAX
:mad:
So I cannot remove this thing!? i took the tabs off the top, two screws from the reverse side on each side..
i think theres something with the tabs on the bottom but i cannot figure this out... and its 30 degrees in VA and im losing it!!
someone help?....... I wanna do my grille tonight and ill post pics of my car, ive been meaning to introduce myself on here.. :biggrin:
nolmt50
Car: 2006 m35
There's a couple tabs on the bottom of the grille (3-4 I think), for me It took a little while and it's kinda tight to get to em.
XGORILLAX
I wish I could take a pic of what I see... its really annoying.. Its annoying that I dont know how to release the tab- I bought the paint and everything but im slowly feeling defeated
XGORILLAX
I dont need to take the bumper off right??
MercMan007
Car: 2007 Infiniti M35
Have you checked the manual?
http://www.nicoclub.com/FSM/M/2007_M45-M35/ei.pdf (Page 16)
CAUTION:
Apply protection tape around outer circumference of front grille (bumper fascia side).
REMOVAL
1. Fully open hood assembly.
2. Remove plastic clip from upper surface of the grille.
3. Remove plastic clip from front bumper upper side (convex part).
4. Pull front grille frontward. Disengage upper side plastic clip joint from back of front grille using pliers. (Figure
to illustration A.)
5. Pull front grille out toward vehicle front. (Figure to illustration B.)
NOTE:
Plastic clips of front grille lower are engaged strongly. Strong power is necessary to disengage them. (When it
is not easy to disengage them, disengage the joint of lower side clip using a screwdriver while pulling the front
grille frontward.)
06M4.5
Car: 2006 M45
pull hard on both sides
XGORILLAX
Thanks for replying and the info.. that plastic peice it says to disengage with pliers is ridiculously tought to get to. I think i squeeze the plastic clip to 'disengage'??
afraid to break it.. but f it.. ive been fighting this clip all day. I want to paint this thing already. I'll be sure to post pics. Hoping it comes out good!!
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
XGORILLAX wrote:Thanks for replying and the info.. that plastic peice it says to disengage with pliers is ridiculously tought to get to. I think i squeeze the plastic clip to 'disengage'??
Lmfao!!! :rotflmao I was afraid to break it myself... A friend and member here, Tyson and I met up and he just pulled that thing out hard didn't break or anything!! I tried it and got!! :dblthumb: good luck!!
MercMan007
Did you get the grille painted yet? Post some PICS!!??
