2007 M35X: All Warning Lights on after bearings changed
ajuersood
Car: 2007 Infiniti M35X
Hi Guys,
I got my front bearing changed (not from the dealer) but now my dashboard is lit up like Christmas lights.
Slip
VDC
ABS all of them constantly on.
I have tried removing the battery connection to reset the on board computer.
I just wanted to ask you all before I take it to the dealer or the mechanic.
Any Ideas????
Thanks
rxmclaren7
Car: 2006 Infiniti M35x
try putting some brake fluid in...those lights indicate that the brake fluid is low!!
shockwave20
Car: 08 m35x, tein h mild drop, 20" rim
If all sensors and wires are ok sometime just driving will take it off
mexillis
Car: M45s
Could also be an abs sensor got pulled too far and is causing the lights to come on.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Were the lights on when you picked the car up?
I bet they broke an ABS sensor (assuming the brake fluid is full). It happens, I've had to buy one for someone else before, it happens.
