Welcome to NICO!
Kingputt323 wrote:Hi Im new to this so here are a few questionsfirst I want to hack my navi screen so my son can watch a DVD while I drivedoes anybody know someone who can do that in the L.A. area?
There are posts here on what to do ... please do a search. However, I am not sure if I recall any mention of somebody in the L.A. area who can do it. But, my memory is always faulty, so I hope some one chimes in!
Kingputt323 wrote:xenon fog lights which are the best to match the factory headlights?
Assuming you are replacing halogens, then folks over here tend to favor Sylvania Silverstars ... a very white light and pretty bright. I forget the exact bulb that is needed, but can look it up if you want! The Silverstars are not xenon, but still very nice!
Kingputt323 wrote:I want to change my rims to 21"x9" & Front 21"x10" Rear. The wheels that I have found have a bolt patern of 5x120 and the hub bore is 72.6 so can these rims fiton my car? or do i have to custom fit the wheels
Hmmm ... the above bolt pattern is wrong for a Nissan Infiniti (standard is 5 x 114.3mm) and the hub is certainly larger than the Nissan/Infiniti standard of 66.06m.
Changing the bolt pattern is a major endeavor and probably not worth the effort. You will need to find a better fit wheel with the right bolt pattern.
For the bore, you could live with the larger bore (since it will not have a problem going on the smaller 66.06mm hub that Nissan uses). But it will put a bit more stress on the lugs - no support in the center! Aligning and torqueing the lug nuts properly (to 85 ft-lbs) and keeping it torqued to the correct value will be essential.
What offset wheels are you looking at? Remember that the current-gen M has very high offset (47 and 50mm) for its 19x8 wheels, and you should get into the right range for wide wheels like what you are considering - too easy to it suspension pars or rub the fender. It would be good to find a friendly wheel/tire place and do a careful fitment test! Or call Tire Rack and ask for an expert who can confirm whether a given wheel size and offset will fit your car.
Finally, please do keep in mind that the correct load index tire in a 21" size is going to be limited in selection, as well as quite expensive! A load index of 94 or 95 (or higher) is important for these cars.
Z
