chairmankaga »
https://forums.nicoclub.com/chairmankaga-u267200.html
Wed Sep 13, 2017 2:25 pm
I got it sorted out. The 54 cm belt was actually a 56.5 cm belt. The part number on the cardboard sleeve was correct, but the belt was different. Who knows. Frustrating, nonetheless.
Ended up with these two Continental gatorback-style belts from Amazon, about $33 total.
Continental Elite 4060450 Poly-V / Serpentine Belt for power steering/alternator. For some reason the 56.4 cm belts are listed as compatible, but they are NOT. You have to get a 54 cm belt.
CRP Industries PK060465 Serpentine Belt for AC.
And despite what the FAQ says, I found the process extremely easy to do from the top, without removing the undertray. Loosen the 14mm capture nuts on the tensioners, loosen them from below, swap, tighten, run the engine for a few minutes, adjust if necessary, lock down the capture nuts to 26 ft lbs. Took me 20 minutes, start to finish, and saved me about $150 in labor.
