I did some searching online, and on this forum regarding an interesting issue I am having with my Infiniti. I couldn't find anything definitive (I apologize in advance if there is already a topic on this issue. I am living in a rural area and tether off my mobile for internet usage so I must conserve my data) I suppose I should mention I have a 2007 Infiniti m35 (base model) with 70,000 miles on the odo. RWD, Nexan tires..
The issue I am having is a wandering problem. The car will dart left then right, then back again on the highway. The problem is most noticeable on heavy rutted roads. It will also dart left then right under hard breaking. Constant correction is required, and my Lada Niva tracks better then my infiniti (and for those of you who know what a Lada is, this really should illustrate how bad my steering truly is haha) There is nothing at all wrong with the breaks that I can see. It seems to me as if it is toeing in and out dependant on wheel position ? (just a theory). I have rotated the tires front to rear, tire position seems to have little bearing on the problem. I used to love driving this car, and quite frankly I hate it now. It's driving me nuts. It has marginal play in the inner tie rod on the passenger side. So marginal I know most technicians wouldn't even find it. You can only find it when the steering is loaded on a drive on style lift. I performed a wheel alignment. I did notice deflection in the steering gear bushings while an assistant turned the wheel. Perhaps a half inch of deflection in the bushings, but they appear to be in tact. I know that they are designed in such a way that a bit of horizontal movement is normal. But this one has got me head scratching a little bit. I really hope its not a fault of the steering gear itself.
Just would like to hear some stories, some advice from people who have had similar issues.
Tomorrow I will see if my scan tool can interrogate any modules and see if there is any fault codes for the speed sensitive steering. I may order new tie rods as well. But, quite frankly it would surprise me this tiny amount of play causing such a huge problem.
Look forward to hearing from you guys. Cheers.
