2007 INFINITI G35X WINDOW WONT GO UP
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
rhamieh
Car: 2007 infiniti g35x sedan
HELP, my rear-right window has gone down and hasnt come up since. I dont think its the fuse, because theres one large fuse for all the windows. Ive removed the door panel but I cant see where the issue lies.. theres no clicking sound when i press the switch either. Help is appreciated! :)
telcoman
rhamieh wrote:. I dont think its the fuse, because theres one large fuse for all the windows. theres no clicking sound when i press the switch either. Help is appreciated!
Have you followed the trouble-shooting steps in the FSM?
Are you testing with the use of a voltmeter?
http://www.nicoclub.com/FSM/G35/Sedan/2 ... an/pwc.pdf
See page PWC 18,19 227, 142
CHECK HARNESS CONTINUITY
1. Turn ignition switch OFF.
2. Disconnect BCM connector and rear power window switch connector.
3. Check continuity between BCM connector and rear power window switch connector
Good luck
Telcoman
pscad
Car: 2007 Infiniti G35x Sedan
Mine would do that. I would have to remove the control panel in the driver side door, unplug both electrical plugs, then plug them back in. That would allow me to roll the window back up. I eventually bought a new control panel, and that fixed it.
Return to “G35 and G37 Interior, Exterior and Audio”
